Could some of you guys with an 05 check the clearance between your hood and fender in the area where the hinges are. Also check to see if the hood edge lines up with the door crease to form a straight line. I've got about 1/2" gap on the left side. The right side is not as bad but the edge of the hood still doesn't line up with the door.
