STORMCAT said:We'll be waiting for the specs and results etc...
PS; How do I post dyno results? I have them in adobe?JRSSR said:I p/u'd my SSR today and drove home 60 miles. Smoother shifting, more tourqe, and appears faster.
Here's a quote from Johan (in charge of R&D)"What i did in the tune was:
Add timing, not much.
Lean out air fuel ratio and allow it to go into PE mode at an earlier
%throttle position. PE mode is same as closed loop.
Remove torque management.
Remove speed limiter
Increase fan speeds and allow the fans to come on earlier."
l'll post dyno when I can.
Jeff
Jeff
tbyrne said:We've had a large order in with Diablo for awhile. That will be ending this way as soon as they release the units. This will cover all of our pre-orders plus we should still have more available for new orders.
Info that we have for this is -
The Predator is a state-of-the art high performance tuning flash programmer, which advances the timing, optimizes the air/fuel ratio and remaps the transmission shift points (in automatic transmissions). Unlike other 'tuners', DiabloSport’s programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery.
This unit has taken the hand-held programmer to a new level. You will notice quicker acceleration and better throttle response. If you have an automatic transmission, the Predator will also give you a firmer, more responsive shift pattern (gas vehicles only at this time). The Predator will raise your rev limiter as well as it allows you to raise your top end speed limiter if you have installed high speed rated tires.
A unique feature of the Predator is that is allows you, the user, to “fine tune” DiabloSports program. Since vehicles are located at different elevations or different weather climates, the way the vehicle responds to the DiabloSport program may vary (not all vehicles are exactly alike). Some vehicles will see better gains than others and some may see better (or worse) gains than advertised. This is due to the fact that not all vehicles respond exactly the same. Now, here’s the good news…If you're not totally satisfied with the way DiabloSport program performs, the Predator allows you to make your own adjustments to the program. For example: If you feel that the shift points are too firm, you can go into the program and lower the transmission line pressure (gas vehicles). If you feel that you can benefit from a higher shift point rpm, you can go into the program and raise shift points. If you feel that you will benefit from a few more degrees of ignition timing, you can go into the program and add some timing (gas vehicles). The Predator allows you to "fine tune" the DiabloSport program to meet your specific requirements.
The Predator has diagnostic abilities near identical to GM’s Tech2 software. The predator will allow you to read diagnostic trouble codes (DTC), erase DTC’s and perform live data monitoring. You can monitor your engine sensors while driving your vehicle and much more.
You will be able to take care of torque management!![]()
JimGnitecki said:Royalshowing: It depends on the circumstances.
The manufacturer cannot unilaterally void your warranty for the mere act of using an aftermarket tune or aftermarket product. He has to establish that it was the tune or product or mod that created the failure that you are trying to get warranty coverage on.
For example, a problem with the air conditioning, or warped brake discs, cannot be blamed on the use of a microtuner.
On the other hand, a custom tune COULD be a contributor to an automatic transmission failure, specially if "torque management" had been disabled by the tune.
And it would almost certainly be blamed for a holed piston caused by too much spark advance.
I would guess that it is the owners with recurring warranty claims that draw the attention of the zone rep or manufacturer, who become suspicious that the history on a particular car is highly unusual. While your swapping PCMs is creative, there are signs that a warranty rep or service manager are instructed to look for on a vehicle that they suspect has been "abused". A couple of those signs are rubber deposits in the rear inner wheel fenders, and of course the condition of the tires relative to the odometer mileage.
You miss many points like "Also Zone SVT rep's have gone to Car Shows/Cruises", these are Not racing events, i think your experience on outer Internet Boards is short. As, said before "Total Warranty Voided" for C&L MAF on Cobras, found Multi Flashing of PCM. I.E. Service Department may have to go in to the PCM to correct a minor problem and by accident find that PCM has been flashed and parameters changed. If, true they will inform GM and your Whole Warranty will be voided. Having been on Corvette Forum, Z06vette.com, Viperalley.com, STLMustangs.com, Stangnet.com, etc. The State Attorney will Not fight with GM, Ford, or D.C. over your warranty. Read the other "Boards" and you will find that it has been done and not just rarely.JimGnitecki said:Regardless of the zone reps' wishes, if you go in with an electrical or paint problem, it's pretty tough for them to try to deny warranty based on a PCM mod. Your state attorney general's office would make that really clear to them.
I'm waiting to hear from Johan at Diablo Sport to bring up my '05 for a final ck up. I'll say one thing, the tourque is up; easy to burn rubber in 1st and 2nd(auto). Gas mileage seems better, I'll know after a few tanks and it shifts better. Does anyone know how I can post my dyno results?AusTexKid said:So, does anyone have any recent info on a release date for the LS2 Predator? (You know, the one this thread is supposed to be about) Last I had heard they were shooting for Dec 1st. Guess they didn't make it. Tbyrne have you been given any info yet?
