Selling my 2005 Aqua Blur SSR, 6 speed manual with less than 8,400 miles. I bought this SSR off of former member - John (a.k.a. Bone Doc) in May of 2017, so I thought I would offer it to members before listing it elsewhere.
Reduced Asking Price, now at $31,000
Asking $33,500 and the list of upgrades / refreshes (mostly done by Bone Doc) are:
-new Optima red top battery (replaced in March 2018)
-upgraded ignition switch
-new Continental Cross Contact UHP tires (estimated to have only 2,300 mile on them)
-bled clutch fluid(Castrol SRF Synthetic fluid) WBP-518 degrees
-bled brakes (Motul 600 RBF fluid DOT 4.0) WBP 420 degrees
-installed ABS module heat shielding (Simple Engineering)
-changed 6 speed manual transmission fluid
-changed Tremec plastic shifter bushing to Bronze type
-changed rear differential fluid / posi additive
-replaced radiator fan with SPAL upgrade (Simple Engineering)
-installed auxillary fan (Simple Engineering)
-reprogrammed to lower temp fan setting (on/off)
-replaced overflow tank with aluminum billet tank/new STANT cap
-new thermostat (latest GM design)
-replaced antifreeze with Prestone concentrate / distilled water
-replaced power steering fluid
-replaced top hydraulic fluid
-replaced all serpentine belts
-upgraded 3rd brake light (flashing) (Simple Engineering) and cargo hatch light to 2 amp LED
-custom front AIR DAM (Simple Engineering)
-installed waterfall SSR badge (interior)
-replaced lower radiator support - metal (Simple Engineering)
-installed upgraded cross member frame brace (Simple Engineering)
-installed front fog light fascia support braces (Simple Engineering)
-replaced alternator with (Tuf-Stuf) 200 amp
-installed LS7 clutch assembly (GM) with bleeder line
-upgraded front frame brace (Left Coast 32)
-installed frame stiffener plate (Simple Engineering)
-installed custom SSR door knobs (Dr. Who) and custom SSR valve stem caps
-installed soft sided SSR saddle cargo bag in bed
-fuse box "copper wire" re-route repair done by "DragonU"
-installed CORSA cat-back stainless steel exhaust system
-installed ACCEL high performance engine coils
-installed interior door handle repair kits (preemptive repair)
-installed LST roof struts (Simple Engineering)
-installed new rear deck lift gas struts and new hood lift gas struts (Vetteman)
-installed new LED back up bulbs and LED bulbs in console gauges
-installed console door lid "popper" upgrade
-upgraded speedo / instrument cluster stepper motors (X27168)
-installed (SINISTER's) dropped and tucked running board brackets
-XPEL paint and headlight protection kits
-DEM soft car cover included
-Battery Tender with wire harness installed
Approximately 8K in parts upgrades (not including labor). A file folder with receipts will be provided to new owner. Thanks everyone, let me know if you have questions,
Sorry, I tried to list my email address as contact information and couldn't do it as this is my first post. So, please respond in this tread with your email address or phone number and I'll respond to your inquiry.
