As much as I have enjoyed the vehicle and this forum, it is time to move on. In the seven years I have owned this car I believe i have taken care of virtually all of the typical issues, including:
New ignition switch (2/23), new battery (11/22), Bridgestone Potenza Tires (8000 mi) -255/45/R19 and 315/35/R20, bed light/fuse fix, new pressure cap/thermostat/hoses, SE high volume fan, air dam, ABS heat shield, new shift cable, lower shift kit, door handle fix kit (passenger), front frame stiffening plate, 4bolt rear crossmember, new main roof struts, new roof system hydraulic reservoir, new bed pneumatic struts, fuse box fix kit, wiper motor pulse board, Muth mirrors, glove box spring kit, LED lights all around, Jeremy Formato performance tune, Corvette servo, cargo bar w/ net, soft saddle bags, SSR embroidered hood blanket.
