1 - 5 of 5 Posts
I went over the production specs for my year but I cant get an actual breakdown on one specific model. I have a slingshot yellow with a 6 speed. The breakdown for yellow says 285 were built which is (10%) of the total production for that year. Then I checked the 6 speed row and see 576 were made (20%) from the total production. BUT how do I know how many yellow 6 speed models were produced? Is there another spreadsheet out there from Chevy? Any light on this would be very helpful. I was looking for something like a Marti report where a total breakdown is given.
ONE OWNER !!!!
Go to Dicktators library and go to the folder Production information !!!!!!!!!! Dicktators Library
You might also want to go to Build Sheet Requests and get a build sheet for your VIN because this will also give Cash more information for his research. I do not believe there is any easy place for the breakdown you are looking for but I am sure Cash will be able to provide an educated guess some day because he is chasing so many VIN #s and sorting them so many ways.
When I tried to track down information it seems records were kept on how many were produced total and each year. Then how many of each color. Then how many 6 speeds but no actual way to check how many of a certain color were 6 speeds. You can get pretty close using the percent numbers but no exact numbers.
If 6000 were produced that year and 2000 were yellow that year that would be 33% were yellow. Then if you can find out how many total were 6 speeds that year, say 200 you could use that same reasoning that 1/3 of the yellow were 6 speeds or close but no accurate way to figure it. It would all be ball park. I do know for sure 74 were produced in 2005 that were all yellow with automatics and shipped to the INDY 500 of which mine is #32 of the 74. Keep looking. Good luck.
Reactions: BlueStreak
Super Moderator
I am tracking the MY2005 SSR 6sp (as well as trying to help finish BYERS total MY2004UV's)
All MY2006 6sp were documented by GM, by VIN & Colour
MY2005 is not so easy - GM did nothing but give a total - and I would not trust that entirely either.
So far, I have documented 1060 of 1637 MY2005 6sp by colour, but don't hold your breath.
I probably have to run 3000 build sheets to find the last 600 - at 20 minutes each - one has to figure out life span - forget the UV searches!
I mean the "life span" a bit facetiously but I am no longer convinced I will finish all this stuff.
Between the 2 it is a daunting task.
Oh, and then there are the wrecked ones!
1 - 5 of 5 Posts
