Guest
·I'm posting this for the benefit of anyone thinking of taking the plunge on 4.56 gears, as my experience has not been all good so far.
FWIW: My vehicle is an early VIN 2003. I replaced the gears and of course the speedo was off, but I also had the traction control kick in when the vehicle hit 2nd gear. I disable the T/C so I can drive it until I get a programmer to change the axle ratio and all will be well, but no, I go through the Crane and Superchips programmers and neither would work with my car at all (BTW, the techs for these companies were less than helpful - Crane in particular wouldn't return a phone call and I'm a friggin dealer). In desperation I try a Predator, which does load, but after correcting the gear ratio the speedo error INCREASES and the traction control is now permanently disabled.
GM techs are scratching their heads on what is going on - they've had the truck for a few days now flashing proms, etc.
Good news is the combo of Predator, Magnaflow and gears has me running with Mustangs and Camaros. That 1-2 shift will slam you back in the seat.
Moral of the story - make sure your truck will work with a programmer that can reprogram the gear change BEFORE you slap the gears in - there are plenty of threads of people having issues with programmers with the SSR.
