1 - 19 of 19 Posts
I have found a part number for a manual transmission mount but these don’t seem to exist... mine is shot does anyone have any ideas where to get one or get one made??? Thanks in advance
Have you checked with Energy Suspension they make a lot of motor mounts and transmission mounts. May not have this but might be worth a try. Is the mount for the SSR used on anything else?
Discussion Starter #9
Sure it’s drivable
Is yours completely trashed and requiring immediate replacement before you can drive it? There may be a solution, but it will take a couple weeks... I just need to know your urgency.
Sure it’s drivable it’s just worn and I know it needs to be replaced I now have 80,000 on her.. thank you for your efforts Mike.
Discussion Starter #12
No apparently it was just for the SSR. It’s a funky looking rascal
What you're seeing might not be what you think. If you take a razor knife, you can trim that sagging rubber flap to reveal a tunnel. Now, if that tunnel is collapsed, then you have a failure. Both my old mount, which was fine, and the new mount I replaced it with had that loose skin on one side.
If you're determined to replace the mount it's a AC Delco part# 22175014 used in Gen 4 Camaro V8 6 speeds. Rock Auto shows them for the 2002 Camaro for $60. That will be the # on your mount when/if you remove it. Good Luck!
Topspin is right about the flap of rubber.
And yes, that looks a lot like the Gen 4 Camaro mount. The part number that I have for it is is 22174970........
Regards,
Mike, your # is for the Pontiac Firebird, while mine is for the Camaro - same part, same price, from Rock Auto. The Camaro part# is what is on my original mount.
Discussion Starter #19
Regards,
Thank you Mike ! You are always helpful!!!!
1 - 19 of 19 Posts
