1 - 5 of 5 Posts
Yes, my ABS light came on while driving recently.
I am told that ABS light will come on with the ignition switch IF it is EBCM but IF it is something else, which it was, ABS light will come on while driving.
Put on Tech 2, code said - ABS Sensor/Hub.
Had my Front/Left/Drivers side Hub and Sensor replaced. No, I didn't do it.
ALL BETTER!
So, sometimes it is NOT just the EBCM, which I had repaired years ago.
My solder repair is still good.
Discussion Starter #4
Shiftz33,
Excellent video. Now you can see why I didn't do it my self.
I was experiencing a slight pull going to Branson and also Dallas. It was wheel hub.
Have polyurethane bushings in front end which made "handling" so much better.
Daily Driver
Just before Branson when I'd come to a stop the pedal would kick up. Couldn't see it but could feel it, no warning lights or messages. When I got home I put the truck in for state inspection and they discovered the ABS was kicking in under 5 mph, and only under 5 mph. Same problem as Dick, left front hub/sensor.
1 - 5 of 5 Posts
