1 - 6 of 6 Posts
coming home from a car show the abs light and the brake liht came on at the same time stayed on all the way home no brake problem when at home shut the truck off and restarted lights went out any ideas
Two most likely things are either the brake module solder issue or it could be a wheel sensor.
The brake module has been known to have problems from the heat off the catalytic converter causing problems with the soldered joints in the brake module that is mounted close to the exhaust. Easy fix remove the module and send it to one of the people who repair them. Dragon2U and Dicktator do repairs. There is how in the library section.
Wheel sensors if they get rust will cause the light to come on. The front bearings have the sensors as part of the assembly but you maybe able to get the sensor by itself.
Did you drive it or just start it?
Ptoblem may be intermittent or depending on problem the ABS module doesn't recognize it until its moving. Weak speed sensor for example.
You should check codes before going too far with any diagnosis.
I did a repair on EBCM last week.
Upper half of ABS.
Brakes will work fine, didn't have ABS back in the 50's and we stopped ok.
Just your light will be on, could be sensor too.
On my SSR HOW TO LIBRARY: Look for ABS BRAKES
Here is another repair house, https://www.myairbags.com
ABS Brake Module Repair
Duration varies • $99
1 - 6 of 6 Posts
