After sitting for a couple of weeks, I took the SSR for a short drive to do some errands. My second stop, I put the top down and continued on as normal. Third stop, shut the motor off, removed ignition key, running lights extinguished as normal, opened the door to get out, and the radio stayed on. Did all the things we all would do, eg., turned the key back on/off and removed several times, restarted, shut off, removed key, opened/closed drivers door several times, still radio on and windows would go up/down, etc. Finally, having an appointment I needed to keep, I shut the radio off, locked the car and went about my business. Back in less than an hour unlocked door keylessly as usual, got in, tried the radio without turning the ignition on, and it didn't come on. Tried windows, etc., and nothing. Started the truck, operated the windows, turned on the radio (everything worked normally) drove to my next destination, stopped truck, turned off as usual, remove key, open door and radio turns off as normal, neither windows nor other accessories would function---all completely back to normal.
Have tried to re-create each day since, but everything works as normal.
What happened???l
What happened???l
