Thank you for your help. Everything worked till I did the fuse box wire so it seems I’m the culprit. Windows work Top retraction works radio works brake pedal feels normal. Dash lights come on then they go off except engine light When I turn the key off the headlights stay on for a while. It’s an automatic The first time or two there was a sound that seemed like it was trying to start to crank now no sounds like thatI posted a wiring diagram for starter circuit on this thread.
Intermittent cranking problem
My 2006 Pac Blue 6 speed baby with only 17,000 miles on her, left me temporarily stranded yesterday and I'm hoping the members can help me find the solution. I had driven into town about 30 minutes away from home and stopped at the local café for some coffee. When I got back in the truck, I...www.ssrfanatic.com
Start here at crank fuse.
I will post more information about testing at start relay if needed.
However more information could be helpful.
Auto or 6 speed?
Did this issue appear right after reinstalling the repaired fuse box?
Is there anything else that would normally work with key on engine off which doesn't work now?
Windows, locks, radio and do gauges sweep as key is turned on.
Check engine light on. Do other lights come on and go out, yet check engine stays on?
Those 3 fuses are good alsoThank you for your help. Everything worked till I did the fuse box wire so it seems I’m the culprit. Windows work Top retraction works radio works brake pedal feels normal. Dash lights come on then they go off except engine light When I turn the key off the headlights stay on for a while. It’s an automatic The first time or two there was a sound that seemed like it was trying to start to crank now no sounds like that
You said "The first time or two there was a sound that seemed like it was trying to start to crank now no sounds like that". Although the lights come on, etc. is it possible that there's just not enough juice to get it to crank over? Dying battery? @Dicktator always says that it needs a minimum of 9 volts at the ignition switch or no-go.Thank you for your help. Everything worked till I did the fuse box wire so it seems I’m the culprit. Windows work Top retraction works radio works brake pedal feels normal. Dash lights come on then they go off except engine light When I turn the key off the headlights stay on for a while. It’s an automatic The first time or two there was a sound that seemed like it was trying to start to crank now no sounds like that
Mike, would trying a fuse box jumper help confirm or eliminate his repair?Hmmmmm, are you sure you put the wire back in the same spot during repair? I always use a marker on the 2 pins so I remember them. If you are off by one then you might have to open it back up.........
I am confident the end result we will fix. I’ll double check wire tomorrow but I sure think I have it correct. I’m charging tonight. I dud not start it before I started the work. So that’s a question Sure appreciate you guys helpYou said "The first time or two there was a sound that seemed like it was trying to start to crank now no sounds like that". Although the lights come on, etc. is it possible that there's just not enough juice to get it to crank over? Dying battery? @Dicktator always says that it needs a minimum of 9 volts at the ignition switch or no-go.
You're in good hands here, but thought I'd throw that out there JIC.
Jumper not really needed for testing, but if you have an assistant and a voltmeter (or a trouble light) you could test fuses for proper 12V when someone turns the key to the start position. There are 2 super small openings in the fuse top. With fuse installed, place one of the voltmeter leads into one of the holes and the other to ground to test for voltage. If you have voltage one one side, then check the other side of the fuse as well. If you have nothing on either side it would be a bad wire internally or something happening before that circuit is bad. If you have it on one side and not the other it would be a blown fuse.Mike, would trying a fuse box jumper help confirm or eliminate his repair?
Underhood Fuse Box - Broken Wire Jumper
Underhood Fuse Box Wire Failure - Jumper NO LONGER OFFERED Some 05 & 06 SSR’s have a Underhood Fuse Box (UFB) wire that “open circuits” when it gets hot. This causes Power Train Relay 42 to drop out and de-energize the 6 engine control fuses. The engine shuts down. Only a small percentage of...www.ssrfanatic.com
Thank you I will double check items todayJumper not really needed for testing, but if you have an assistant and a voltmeter (or a trouble light) you could test fuses for proper 12V when someone turns the key to the start position. There are 2 super small openings in the fuse top. With fuse installed, place one of the voltmeter leads into one of the holes and the other to ground to test for voltage. If you have voltage one one side, then check the other side of the fuse as well. If you have nothing on either side it would be a bad wire internally or something happening before that circuit is bad. If you have it on one side and not the other it would be a blown fuse.
Fuses 36, 33, 28, 35, and 29 are the ones that fail when relay 42 looses voltage from the wire you replaced. If they are all dead then the internal replaced wire is suspect.
Other questions -
How did you secure the copper wire to the silver terminal? Maybe it popped off during reassembly? I use a very thin screwdriver blade with a light hammer and tap it into place snugly.
Are all relays in the proper orientation? It does matter how they are placed.
Are all fuses in proper position? Maybe missed one by one position?
Here is a pic of one of ours, equipped with spare fuses. As @Dragon2U says the relay orientation is important.Thank you I will double check items today
The battery light came on. I took it down they said it’s good and they are full charging. I double checked the new wire it looks good I checked fuse positions with my pic before removing. Starting to get anxious. I’ll go back and get the battery and try to check fuses. It’s an 06 automatic.Agree with @Dragon2U -- use test light or voltmeter to test fuses.
here is an explanation for testing at starter relay which I did for someone else that might help --- note other fuses of importance to get car cranking. NOTE if automatic then pin 85 is still from fuse #23 IGN E but it feeds thru the park, neutral switch on transmission
Thanks to @TXNSSR for the picture -- I added some to it
BE sure transmission is in park or neutral BEFORE testing at ANY starter relay on ANY car
You can jump power to crank fuse to bypass ignition switch BUT being a 6 speed someone would need to depress clutch in order for it to crank and because key has to be on - it should start.
If its an automatic and you do this car will start with key on and trans in P or N.
You will find a picture explaining the tests at the starter relay (which is #43 not 42) these voltage reading would be taken with relay installed --- lift up slightly to slide red lead of voltmeter under just enough to touch relay pins. Or slide hat pin (T shaped pin) or similar under and touch that with meter lead. - be sure not to touch more than one pin.
If you remove relay:
you can test pins 30 and 85 for 12 volts with black lead on ground -- note key must be on AND clutch depressed (or in P or N) for pin 85.
Then to test pin 86 place red in pin 85 and black lead at pin 86. You should get 12 volts with clutch depressed and key in crank
OOPs I left off fuse #39 -- green 40 amp one, farthest up on the right! (NOTE his fuses that are surrounded with white paint are all spares)
View attachment 590664 .
Ok I have a lot of fuses without power. These were with the switch on. I also tried a couple of pins of the relays no luck. Here are my notes on power yes or no for fuses
