Yesterday afternoon when I returned home, I locked the doors and set the alarm as I usually do. The doors locked fine, but when trying to set alarm, no lights flashed, and no horn honk, but the doors did lock again. So, I repeated the process, no luck. I thought, ok, first item on list for dealer.
Well, I decided to try again, still no luck. As I started to walk around and check out truck, I noticed the driver window was about 1/2" from being completely closed, I rolled it up all the way, tried to set the alarm then, and, :thumbs , all worked just fine. I guess GM figured this was a way to make sure the truck was completly secure, leaving no open window as a temptation to a thief.
I'm not sure if this has happened to anyone else, but if it does, check the windows, could be the answer as it was for me.
:ssr drtrcer
:ssr drtrcer
