Ok, after doing hours of research, and not wanting to be stuck with Goodyear tires with 220 tread rating, I think I have found a good substitute.
Toyo makes same size tires for the rear, and have a 19" tire that is only 2.48 % bigger, which is acceptable. Tire size is 275/45/19.
The tread ratings for these tires is 420, almost twice the treadware of the Goodyear tires.
The tire is Toyo, Proxes S/T. Anyone agree or disagree?
Thanks
Yes, I have an ATTITUDE !
Thanks
You can't put that on the factory rear rim, they are 20's
Machell
These are the sizes BobA had
put 275/45R19 108Y toyo tires on front and
315/35R20 106W on back
no problems no rubbs when turning all left or right. looks good
tire size
front 255x45x19 = 28.04" height
rear 295x40x20 = 29.29" height
these are the factory sizes
Thanks
Will the Toyo tires stick as well as the goodyears? (Usually the higher the tread wear, the harder the tire, the less stick it has, right?)
