1 - 9 of 9 Posts
Has any one had the experience of replacing the ignition switch (AC DELCO gray housing) only to find out it was defective. While I had my steering wheel apart searching for the grinding noise I decided to replace ignition switch that I had in my glove box for about a year. After numerous attempts to get it started and doing fuse checks, ground checks, charging battery. I decided to install old switch that I never had problems with. Guess it works like it is supposed to. Another case of WHY ME!!!!!!!
Why me!........would have been, for me, taking out bad switch then replacing with new switch and finding out it was bad also!!!
So far I've had a defective brand new acdelco water pump, a defective brand new acdelco master cylinder, a brand new defective acdelco transmission gasket and yes, a brand new defective acdelco abs sensor. It seems that quality control and cost cutting are a problem in shifting production offshore. You only had one, count yourself lucky!
Discussion Starter · #5 ·
Possibly an endorsement for . . .
"If it ain't broken . . . DON'T FIX IT."
! /forum/images/SSRFanatic_2016/smilies/tango_face_surprise.png ! /forum/images/SSRFanatic_2016/smilies/tango_face_devil.png ! /forum/images/SSRFanatic_2016/smilies/tango_face_surprise.png ! /forum/images/SSRFanatic_2016/smilies/tango_face_devil.png ! /forum/images/SSRFanatic_2016/smilies/tango_face_surprise.png !
Amen on that, so many people have said replace ignition switch, until I know it is bad it is staying right were it is at.
RedHotSSR
Electrical parts.
Learned a VERY long time ago to NEVER purchase an electrical part and NOT install it ASAP. If the replaced part is still working and this is a "Preventive Maintenance" project. Mark the OLD part as "USED" but still working and keep it as a backup. You loose the warrantee on most new electrical parts in most cases after 90 days. Out the box / new along with low mileage Rs does not guarantee trouble FREE.
"Long may you run"
Ret. Air Force
Robert,
This may be a silly question...but...did you make sure the small gear wheel at the top was in the correct position before installing? I remember the person helping me install mine had to click that gear wheel twice before installing it.
Alex
Discussion Starter · #9 ·
Robert,
Alex
I had that switching every position you think of, well not quite. I even did what dictator said roll it with your thumb to make sure it starts no go so the only thing I can figure is a bad switch put the old one back in.thanks Alex.
1 - 9 of 9 Posts
