Shown in the attached photos is a tip that will facilitate removal of the battery on your SSR. Instead of lifting the battery up and over the lip of the battery tray, then awkwardly wrestling it to the ground while you are on your back, simply lift up the rear edge of the battery and insert a small piece of ¼ inch thick plywood under the battery. This plywood will serve as a “ramp” onto which you can then slide the battery onto another support like a box or used milk crate. Slide the box or crate sideways to the left and you have more room to then guide the battery to the ground for removal.
