1 - 6 of 6 Posts
Help:
I'm installing carpet and bed cover liner, and can't find wiring harness for the dome light. The left side hinge has a switch with just one wire, ground. Is this wireing harness a seperate part number that didn't get ordered? Which way is it routed, does it come out from behind left hinge? Were does it plug in at? Can I go ahead and install the carpeting and put the bed cover back on, or is this in the way of wiring harness routing? Any help would be welcomed.
P. S. My bed cover pops up first time all the time, I can't wait to see if it still pops all the way up with the weight of the cover liner.
SSR is 03 #913
Thank you, :confused
Ted
· Senior Privileged Member
Ted: There is a TSB addressing the wiring for the light. It is:
TSB 2058 dated 1/1/2004 but shown listed 7/9/2004.
Check with your dealer.
By the way, this information comes off the neat TSB Excel worksheet that someone else on this board published here just yesterday or so.
Discussion Starter · #5 ·
Part numbers for bed carpet
Part #s
15118532 Bedliner Asm. Carpet bottom sides and front
15118527 Trim under bed cover
11610086 Bolt plastic fabric covered push pins 18 to hold bed cover up 4 for rear of carpet kit
15118237 Stripe oak wood floor strips
Ordered wiring harness for dome light today don't know part # yet
I hope to figure out were this wiring harness plugs in when I get it. The parts man said it looks like it starts at the left tail light area and exits out the left hinge. What a pain this has been. If I only would have known when ordering the ssr. Ordered first one in San Diego area sight unseen they didn't even have a brochure or a clue as to options.
Ted:seeya
1 - 6 of 6 Posts
