1 - 5 of 5 Posts
Mike Moro informed me while at Cincinnati Rally that the screw connector on the Bed Light was causing a problem. SHORT!
He told me to "clean" pins on connector, that it has, or most do, green corrosion that "leaks" causing fuse to blow.
IF you changed your Bed Light to LED and 1 or 2amp fuse, at least you won't do any damage.
THANKS MIKE! I blew 1 amp fuse while in Cincinnati, replaced and didn't think about it. Well it happened when I got home, replaced and happened again. I know! I'm slow learner.
YES! Screw connector had "crap" in it!
ALL BETTER! Do it! Check your Bed Light Connection.
Discussion Starter · #2 ·
Bed light fuse also sun visor lights is in rear fuse box.
DON'T WAIT! One pin goes to Roof Door Module, could and has "stopped" roof from working.
Lost In The 50's
Thanks Dictator: I just checked my '03 and it looks just like the day it came out of the factory. The one you are showing is nasty. How did it get like that? Just curious.
Reactions: richsadams
Discussion Starter · #4 ·
Probably because I drive it.
159,000 miles, 15yrs, Canada twice, NE, Branson, Maggie, Cincinnati, Dallas twice, Calif, Los Vegas, North Dakota. And all over Florida!
Try it, you'll like it.
1 - 5 of 5 Posts
