  •  2022 Ride of the Year
1 - 9 of 9 Posts
· Premium Member
Anyone out there install a bed light? If so, what part number did you use? Where does it mount? Do you like it? Does it give enough light for you? And how much was it?
Thanks! I'm sure I'm not the only one that needs to see in the dark!!
GR :seeya
Mine came with it, but it wasn't hooked up. I knew it wasn't susposed to be THAT dark at night. :cool So I finally got a look at it in the daylight, and figured out where to plug it in.
If you add the cargo cover trim, you need to change the wiring harness from the hinge to left tail light area. Part # 15115930 Harness $103.00 Use the existing harness unpluged from left hinge mount switch to pull new harness through. Plugs in under cover latch mechinism (black box) under tail light. After you install this nice looking upolstery the cargo cover won't lift fully open unassisted anymore, pops up 2 inches, but looks cool :cool
Later Ted
· Premium Member
Discussion Starter · #9 ·
I gotta brain fart after reading some of these posts... there's a lighter plug or access. plug in the back left side of the tailgate, I'll just find a lamp or light plug to put back there probly costs $10.
I'll keep you posted!
GR
1 - 9 of 9 Posts
