2004 Chevrolet Super Sport Roadster (SSR)…Performance tuned...55,439 miles
  • Have dates and costs for all items listed below.
SAFETY SYSTEM UPGRADES
  • Pioneer Navigation System/Backup Camera/Bluetooth Audio with Android and iPhone USB plug-ins
  • Blind Spot Detection System Visual and Audible
INTEGRITY and PREVENTIVE MAINTENANCE UPGRADES*
(*Sourced from Simple-Engineering.com or The Dicktator)
  • Lower Radiator Mount/Support
  • Direct Replacement Main Fan
  • Front Frame Stiffening Plate
  • 4 Bolt Rear Crossmember
  • Upgraded Upper and Lower Control Arm Urethane Bushings
  • Roof Hydraulic Cylinders Rebuilt (All; Partial 3yr Cabriolet Hydraulics warranty remains)
  • Replacement Air Dam
  • ABS Heat Shield
  • Transmission Shifter Repair Kit (upper and lower)
  • Ignition Switch
  • Hood Emblem Support
  • Blinking Third Brake Light
COSMETIC/CONVENIENCE UPGRADES
  • Engine Cover Custom Matching Paint
  • Refinished Hood/Front Fender Road/rock pits
  • Painted Grill/License Plate Grill/Running Boards
  • Pin Stripe Hand Painted
  • Rear License Plate Grill (C5 Corvette)
  • LST Hood Lift/Support Struts
  • Replaced LST Tonneau cover lift/support struts
  • Sinister Kustoms Dropped/Tucked Running Board Brackets
  • 5” Stainless Steel Exhaust Tips
  • Headliner Replaced
  • Racing Stripe Wrap
  • LED Instrument Panel Lighting Upgrades
MAINTENANCE/REPAIR WORK
  • Brake Master Cylinder (Replaced front Calipers, Pads, Hoses as Preventive Maintenance)
  • Rear Deck/Tonneau Cover Release Actuator
  • Windshield Washer Pump and 2005 Wiper Arms with Upgrade Spray Nozzles
  • Air Conditioner Fitting/Evac/Recharge
  • Rear Suspension Bump Stops
  • Atturo 205/40/20 rear tire replacement
  • Atturo 255/50R-19 front tire replacement
  • Performance Electronic Tune…will bark rear tires going to 2nd…
  • Battery Replaced 05/21/20
  • Transmission Full Synthetic Flush
  • Rear Differential Full Synthetic Drain and Fill
  • (Not included are routine oil change/services 3,000 miles or annually)
ACCESSORIES
  • Cockpit Windbreak Screen
  • SSR Logo Under Hood Lettering
  • SSR Logo Carpeted Floor Mats (Show mats; in addition to regular Logo rubber and carpet mats)
  • SSR Logo Carpeted Cargo Mat
  • SSR Logo Seat Belt and Door Pull Covers
  • SSR Logo Valve Stems
  • Big Bird Dash Mat
  • Front Hood Bra and Mirror Covers (new, used once)
