1 - 20 of 21 Posts
Blue Led's, Door Handle, Door Pocket, Door's for Puddle Lights & Console:nerd:
Power for Console From Rear Fuse Block. Lift Lid ON, Close & Lift Again For Off:nerd:
:purple::cool:shades:
Discussion Starter #3
Thanks I Do Too
Great Visual Crusing At Night…..
Blue Would Look Good On Most Of The R's
:smile2:
How was the door handle piece made that is on the handles? The Carbon Fiber and SSR logo look good. I have not seen that before.
Discussion Starter #8
Carbon Fiber Look on Handles Are Decals, I Got Them From "Dicktator"
They really look good Dennie! Nice getting to know you and the Mrs. at Daytona!
Discussion Starter #11
I Will Attempt To Create A How To For Led's
It Will Be Good Task For Me To Create Instructions With Pictures...
Will Look For Pic's Of Mounting Led In Handle, Not Sure If I Took Any ??
Door Handle & Door Pocket Together...Same Circuit..
Puddle Light Separate...Circuit
Coming Soon
:smile2::shades:
2006 Automatic
How is the instruction manual for leds coming?
I am particularly interested in the info for the mirror turn signal and puddle lights.
What I really need to know is what LEDs you used for each and maybe where you got them.
The wiring I can probably figure out for myself?????
Thanks for the good ideas and your hard work.
Discussion Starter #13
Mirror Les
Turn Signal Bolt Beam 12mm LED Light - 55 Lumens - Yellow Black From SuperBrightLeds.com
Puddle High Intensity Flush Mount LED Bolt, 11MM, Cool White with no lens True Flush Mount.... Oznium.com
Door Handle Blue 6MM from Oznium
Wiring a "Bear" but worth it:nerd:
Looks nice. Around here no blue if the vehicle is moving. Blue is the cops color only and they will ticket you. Needs a switch to shut it off if vehicle is moving. Only colors allowed on moving vehicle is amber, white or red to the rear. We did get the law to allow blue dot tail lights so they are allowed now.
2006 Automatic
Mine are on order!
Did you put in a switch for the light in the console?
I take it that the puddle light is on the inside position of the mirror and the turn light is on the outside position.
Thanks
Discussion Starter #20
Pudle & Turn Signal
Yes I used a switch, put it on the back under side of the lid. You lift once & its on & lift again it's off.
Yes, Puddle to the inside & Turn on the outside...
1 - 20 of 21 Posts
