dougnc -- maybe the oxygen sensor broke during the "love tap".dougnc said:Well, after getting tapped on the rear end they had to replece exhaust system. Now it runs rough and the little engine lite is on, indicating emmissions problems.
What could they have done wrong? They're kind of clueless here.
Would the oxygen sensor make it run rough?Gary's 04 said:dougnc -- maybe the oxygen sensor broke during the "love tap".
Gary
Oh yeah, BIG TIME!dougnc said:Would the oxygen sensor make it run rough?
The oxygen sensor is a very, very fragile instrument. Even when replacing one with a new one you have to be very careful to not have hit anything upon insertioninto the bung. Lots of experience here!dougnc said:Would the oxygen sensor make it run rough?
Four?matjow said:If all they did was the exhaust, sounds like they broke one of the four O2 sensors. You have a pre-cat and post-cat O2 sensor on each side. They are very fragile and generally sensative.
I guess now you have something against us hung over Russians????dougnc said:Four?
Well, I told the body guy it was the sensors. So now this hung over Russian is going to be hot roding my SSR down to the dealer.
I can sure tell why insurance is so expensive.
On the bright side, the old pipes had been damaged somewhere. The new ones look much better!
Doesn't every vehicle come with 4 sensors? We had a terrible time with the x-cab chevy P/U!! I think replace all of them to get the engine light to finally go off!!! What a pain that was. :boxingmatjow said:If all they did was the exhaust, sounds like they broke one of the four O2 sensors. You have a pre-cat and post-cat O2 sensor on each side. They are very fragile and generally sensative.
He ha. Sounds like they didn't have a clue which was bad, and it was your misfortune that the found the bad one last.wildcat66 said:Doesn't every vehicle come with 4 sensors? We had a terrible time with the x-cab chevy P/U!! I think replace all of them to get the engine light to finally go off!!! What a pain that was. :boxing
Kewl! Too bad you don't own a Redline tho, the red goth chicks like corsets.An SSR's Wife said:I guess now you have something against us hung over Russians????
Well at least I have my own SSR to hot rod around.....
And, I bought that matching lipstick too :lol
But then I'd have to open the box! :lolbeer100 said:look for DTC codes. They are noted through out the manual. There is also a huge list as I recall.
