  •  2022 Ride of the Year
1 - 5 of 5 Posts
2003 Chev SSR Black with flame job
Hey all,
Has anyone found a brake mfgr that does the 14" rotor upgrade yet?
I talked with Baer and it doesn't sound like they are too interested. I just want to get larger rotors and backer plates and slotted Not drilled .
· Premium Member
Also used Rotorprops - great pricing.
Larger aftermarket rotors would be extremely pricy, and would require calipers as well.
Ray
· Resident Rocket Scientist
Ray
Actually the larger diameter rotors would not necessarily require new calipers. They would however, require at a minimum relocation of the calipers.
Discussion Starter · #5 ·
Brakes
Hey Guys,
I guess my qestion should be," Do the 12.75" rotorpro rotors stop better than stock or is it neccessary to increase the diameter to 14" with the use of larger radius brackets?" There is no question that these rotors look much better than stock.
1 - 5 of 5 Posts
