1 - 11 of 11 Posts
Super Moderator
I have copied every build sheet ever posted on the forum, and have edited them to my taste for ease of reading.
Thanks so much to Umpire 13 and MarcNY for carrying on posting these
Marc does a fantastic job of looking after the Build Sheet Request thread - and he posts them as they come off the GM site.
I'm not sure what everyone does when they receive their Build Sheets, but if you print them off, this is what I do to make them more "reader friendly"
I have a very good example to work with that Marc just posted
I will copy it here and in Post 2 will show what it looks like in modified form.
All I do is format - I do not alter the content
It looks a lot better here than in the original thread, but I still improve it
Example - as posted by Marc
Vehicle Information
VIN: 1GCES14P24B108966 Model: CS15703-2004 CHEVROLET SSR
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Vehicle Build
Model: CS15703-2004 CHEVROLET SSR Order Number: HDQH0S
Gross Vehicle Weight: 2,747 Build Date: 04/26/2004
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
192 - EBONY 19I - BLACK INTERIOR TRIM
1SB - 1SB PREFERRED EQUIPMENT GROUP CONSISTS OF: ENGINE COVER INSERT MEMORY PACKAGE -SEATS,RADIO,DIC HEATED DRIVER & PASSENGER SEATS ELECTROCHROMIC MIRRORS: INSIDE REARVIEW & LEFT O/S REARVIEW HOMELINK AM/FM STEREO W/IN DASH 6 CD BOSE PREMIUM SOUND SYSTEM OPTION PACKAGE 02 1SZ - PREFERRED EQUIPMENT SAVINGS
6DL - FRONT SPRING 79U - PREM. COLOR SLINGSHOT YELLOW
7DL - FRONT SPRING 8KL - SUSPENSION
96P - ULTRA SILVER WHEEL PAINT 9KL - SUSPENSION
A31 - POWER WINDOWS A95 - HIGH BACK RECLINING BUCKET SEATS WITH FLOOR CONSOLE
AAB - MEMORY DRIVER CONVENIENCE PKG AJ1 - DEEP TINTED GLASS
AJ7 - DR/PASS FRT & SIDE AIRBAGS AU0 - KEYLESS REMOTE DOOR LOCK
B30 - WHEELHOUSING & FLOOR CARPETING BCP - ENGINE COVER INSERT
BKF - CUSTOMIZED FLOOR MATS ***DEALER INSTALLED*** BVE - INTEGRATED RUNNING BOARDS ***DEALER INSTALLED***
C49 - ELECTRIC REAR WINDOW DEFOGGER CJ3 - CLIMATE CONTROL
CTD - CARGO NETTING PKG CONSISTS OF CARGO NET, ONE CROSSBAR AND FOUR TIE DOWN RINGS ***DEALER INSTALLED*** DJ2 - ISRVM LT SENSITIVE HOME CONV
DNR - DEALER INSTALLED EQUIPMENT DR2 - MIRROR O/S LH & RH REMOTE CONT ELECTRICHEATED LT SENSITIVE MANUAL FOLDING COLOR
E55 - TAILGATE BODY EB6 - GVW RATING 6,050 LBS
ERK - CARGO COMPARTMENT TRIM W/WOOD EVA - EVAP EMISSION REQUIREMENT
FE9 - 50-STATE EMISSIONS G80 - LOCKING DIFFERENTIAL-REAR AXLE
GT4 - REAR AXLE - 3.73 RATIO JF8 - BRAKE VAC POWER, 4 WHL DISC
JJA - PT DRESS SUBASSEMBLY INSTALLED K34 - ELECTRONIC SPEED CONTROL WITH RESUME SPEED
KA1 - HEATED FRONT SEATS HEATED DRIVER SEAT KG3 - 145 AMP ALTERNATOR
LM4 - VORTEC 5300 V-8 SFI ENGINE M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL
N40 - POWER STEERING NT9 - FED EMIS SYS TIER 2 PHASE-OUT
NW7 - TRACTION ASSIST OLF - PLANT CODE - LANSING, MI
PD7 - WHEEL, SPARE DELETE PZ7 - WHEELS, 19X8 FRT, 20X10 RR
QMX - TIRE, ALL MIXED SIZES FRT & RR RAE - INTEGRATED SIDE SADDLE STOR. ***DEALER INSTALLED***
SLM - STOCK ORDERS STW - LEATHER WRAPPED STEERING WHEEL
T61 - DAYTIME RUNNING LIGHTS T96 - FRONT FOG LAMPS
T98 - STAMPING VEHICLE IDENT NUMBER U68 - DRIVER INFO CENTER DISPLAY
U73 - FIXED MAST ANTENNA UA6 - THEFT DETERRENT ALARM SYSTEM
UC6 - AM/FM STEREO W/IN-DASH 6 CD UQA - BOSE PREMIUM SOUND SYSTEM
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA VK3 - FRONT LICENSE PLATE BRACKET FRONT LICENSE PLATE MOUNT
VR4 - TOWING PKG. HITCH INSERT ***DEALER INSTALLED*** WEIGHT DISTRIB. PLATFORM HITCH VXS - COMPLETE VEHICLE LABEL
X88 - CHEVROLET CONVERSION YC5 - LT DECOR EXTERIOR APPEARANCE PACKAGE
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX YD5 - BASE FRONT SPRING
YD6 - BASE REAR SPRING Z82 - HD TRAILERING EQUIPMENT
ZQ8 - SPORT HANDLING PACKAGE ZY1 - SOLID PAINT
Super Moderator
Discussion Starter · #2 · (Edited)
This is what I do to all Build Sheets to make them - not sure - just more appealing to the reader
1GCES14P24B108966
Vehicle Build
Option Codes
1SB - 1SB PREFERRED EQUIPMENT GROUP CONSISTS OF: ENGINE COVER INSERT MEMORY PACKAGE - SEATS, RADIO, DIC HEATED DRIVER & PASSENGER SEATS ELECTROCHROMIC MIRRORS: INSIDE REARVIEW & LEFT O/S REARVIEW HOMELINK AM/FM STEREO W/IN DASH 6 CD BOSE PREMIUM SOUND SYSTEM OPTION PACKAGE 02
6DL - FRONT SPRING 7DL - FRONT SPRING
8KL - SUSPENSION 9KL - SUSPENSION
A31 - POWER WINDOWS
DR2 - MIRROR O/S LH & RH REMOTE CONT ELECTRIC HEATED LT SENSITIVE MANUAL FOLDING COLOR
G80 - LOCKING DIFFERENTIAL-REAR AXLE GT4 - REAR AXLE - 3.73 RATIO
VXS - COMPLETE VEHICLE LABEL X88 - CHEVROLET CONVERSION
YD5 - BASE FRONT SPRING YD6 - BASE REAR SPRING
Build sheets vary a lot, obviously, and when it comes to MY2005 I hi-lite the M10 6sp, in MY2006 the VYJ chrome package.
I give anything of "importance" it's own line - i.e. BVE(F) CTD C44 ERG(H) DT3 ERK RAE E80 VR4 M10 VYJ
I also move i.e. A95 onto its own line - anything that is secondary on a line jointly occupied, yet it goes onto the next line.
By doing that, the second line starts with an RPO, yet still only 2 lines are used (it doesn't extend the length of the build sheet - just makes it clearer)
Often you will see something like BVE right at the end of a line - I move it forward on its own line
In this example (Post 1), the 6DL, 79U, 7DL are all messed
I like to have the 6DL/7DL on the same line, so I cut & paste the 7DL
Then the 79U - this keeps the "7's" still in line
Next was the 96P - I moved the 8DL/9DL onto the same line - then the 96P, so the "9's" are okay
Most of the RPO's on our Build Sheets are common to all SSR's so I don't worry too much about giving them each a line, but I do like to keep their kinship
i.e. G80, GT4 - both differential related
T61, T96 - both light related
YD5, YD6 - both rear spring related
Super Moderator
Discussion Starter · #3 ·
If anyone that has had their's run and wants my edited version, PM me your VIN & email address
Super Moderator
Discussion Starter · #4 · (Edited)
Had a bunch of personal requests - all is good!
Wouldn't mind if some of them reported in here, saying my stuff is okay
It is all original - I just move some stuff about - the way GM should have done it originally
Super Moderator
Discussion Starter · #6 ·
Thanks, Dave and thanks very much Marc for your acceptance of what I do.
Vehicle Information
Vehicle Build
Option Codes
BKF - CUSTOMIZED FLOOR MATS DEALER INSTALLED BVE - INTEGRATED RUNNING BOARDS DEALER INSTALLED
CTD - CARGO NETTING PKG CONSISTS OF CARGO NET, ONE CROSSBAR AND FOUR TIE DOWN RINGS DEALER INSTALLED DJ2 - ISRVM LT SENSITIVE HOME CONV
QMX - TIRE, ALL MIXED SIZES FRT & RR RAE - INTEGRATED SIDE SADDLE STOR. DEALER INSTALLED
VR4 - TOWING PKG. HITCH INSERT DEALER INSTALLED WEIGHT DISTRIB. PLATFORM HITCH VXS - COMPLETE VEHICLE LABEL
I have had my 04 SSR less than a year. Ordered my build sheet a couple of days ago and received the next day.
When going through the sheet, there are items listed that are not part of SSR now. That makes me think that some items have been removed before it had been sold. Running boards, integrated side-saddle storage, cargo compartment trim package, towing pkg. weight list. platform trailer hitch,,,,,! Also, there are two types of wheels listed.
I'm not sure what I SHOULD have. Confusing!!
Administrator
PEDIGREE SSR
Sometimes that will happen. FYI: some owners liked the looks of an SSR without running boards and perhaps they took them off and or most likely sold them. The integrated side-saddle storage had a tendency to take up space in the rear and for some were also a little bit cumbersome to use. Trailer hitch might not have been used so the previous owner may have kept it or more likely has sold it. Not sure why two styles of wheels were listed, Yes, there were two types of wheels available (Satin or Chrome) but you only received what was actually ordered on the SSR. It is possible that the SSR owner may have sold their previous wheels and may have put on another set of i.e. Chrome wheels. I don't know why the cargo compartment trim package was missing. It is hard to find but you can still find a few trim kits still around.
EDIT: Some dealers or sellers will advertise a loaded SSR and might strip the SSR of a few sellable parts thinking the owner would never know what was actually on the SSR before they purchased it. (n):mad:
Thanks Marc. I have the window sticker to make a comparison, it makes sense that somewhere along them line items were removed and probably sold.
The build sheet also an electronic compass as part of the Driver Information Center. I have not been able to access it.
Thanks for the info!!
Daily Driver
Two types of wheels listed? Would that be the front 8 inch and rear 10 inch? Just a guess I've no idea if they would list separately.
I think the 8 inch and 10 inch may have to do with the size of the tires?
I have 19" wheels on the front and 20" wheels on the back.
1st. wheel listing - 14P - Polished chrome alum wheels (4) silver in color
2nd. wheel listing - P27 - Painted aluminum wheels (4)
1st. wheel listed is what I have on my SSR.
1 - 11 of 11 Posts
