Where exactly is the leak? Window, windshield? Is the window aligned? That would be my fist check. There are several ways to check that. and fix.
Hey there Guest! Check out the current Ride of the Month contest. View and vote on the submissions from the community fanatics vying for the coveted ROTM award! |
Hey there Guest! Did you know an International Rally is coming up in September? Check out the International Rally Information here. We hope to see you there!
Had this on my 03. Had the dealership replace the roof weatherstrip to correct this problem. Appearantly there have been a few defective weatherstrips that just won't seal at the roof joint. When I removed mine for painting I found that the weatherstrip really has no adjustments like it should. The rear weatherstrip going up the rear roof section can be adjusted up wards if needed. Another thing to do is, apply a thin layer of vaseline on the weatherstrips to ensure a good seal and prolong the softness and life of the weatherstrips. Don't put too much on, as it will create a messy situation.PrincessZag said:I've had my new '04 SSR for three weeks now. It's been leaking on both the driver and passenger sides since the day I drove it off the lot. I made an appt. with the body shop to look at it next week. What info do they need to know to fix it. I doubt they have any experieince in this area and would like to bring some with me.
:seeya
