It appears my 05 SSR's HVAC system has decided that I don't know what temperature I would like the cab to be while I'm driving.
The left hand dial knob (temp knob) of the HVAC controls does not result in a change in the air being let into the cab with the blower motor on. Only when I turn the mode dial knob (right most dial knob) to the full defrost setting (last clockwise notch) does the temp of the air become warm/hot. That seems to suggest the heater core and air flow around the core is ok, just not the control line from the left temp dial knob.
About 1 of every 5 startups can I get some heat out of the system, but it's very random.
I searched for anyone else with this problem and I didn't see any postings relating to this issue. I also searched the NHTSA TSB listing and I only found one TSB relating to HVAC blower motor not being turned on properly.
I already had an appointment scheduled on Monday 12/19/05 for a few issues.
1) Rear end whine noise (ring and pinion gear changes)
2) Oil leak near the starter motor and draining down the transmission bell housing
3) Electric motor like "whirring" noise (with the colder temp) from behind the driver seat (fuel pump?)
4) And now #4, HVAC temp control knob does not regulate the temp of the air blowing out of the air vents.
This should be a fun trip to the service department on Monday.
