1 - 13 of 13 Posts
Banned
Im wondering if anyone has added the factory dome light or did some kind of aftermarket type. Pictures would be great also!...:)
Bed Lights
I am installing two oval LED Lights on the inside lid, switch will be located in the lighter area
Banned
Discussion Starter #3
Oh please do take pictures and document the install.
I have the light in under the bed but it does not come on. Is there a possibly a connection that is not hooked up or something? Looks like it should work.
Banned
Well the first two things to check are the bulb and the quick disconnect clip on the wire that allows you to remove the lid. If thats not the cause check for a ground fault.
I bought a goose neck light that plugs into the cigarette outlet in the back - Radio Shack for 12 bucks - can point it anywhere. Documenting the install - insert tip, walk forward slowly.....
SSR Owners Group
You forgot the safety disclaimer: Do not point directly into your face! :glol
Banned
Discussion Starter #8
Sounds more like directions for sex to me.....
Add, Do not stare into bright light with remaining good eye. :banghead
Helpful
So, Ricochet - you finding this thread helpful considering the original question?? :glol :glol
1 - 13 of 13 Posts
