1 - 8 of 8 Posts
Click on your avatar in the upper right of the screen. That will open a window with a menu. Just below the line and above Log Out is a link to Account Settings. Click that link and you will be where you can make changes . You sill see a place under your picture that says Click the image to change your avatar. you should be able to handle it from there.
Spirited driver!
Double-click on your avatar. This will take you to your account details. Then you will see the option to click on the picture to change it:
565932
I'm not sure what really worked for me, luck/accident, but I think I had to DELETE the first one that turned into a Box with a ? in it.
Ok... I can change my avatar easy enough.. but I'll be danged if I can figure out how to get rid of that "Premium Member" and put something exceedingly clever in it's place. :unsure::unsure::unsure:
1 - 8 of 8 Posts
