1 - 11 of 11 Posts
Has anyone had any experience changing from 19" to 18" on the front of your SSR? Not many wheel options for a 19" and what fitment problems are there? Thanks:black:
Proud Original Owner
Check with Rogerdoger, he has 18" Coddington wheels on front.
20" on back. No problems as far as I know.
I am using 18's on my 2006, the extra sidewall height does make the ride more comfy, since I don't throw the truck into corners I cant speak to the handling deficit the difference creates. I do feel more confident on the rough roads in these parts as I have more confidence I wont bend a rim. I am using a Mickey Thompson 28x10x18 tire, same height as stock, about 4 tenths of an inch more narrow, same backspacing on the rim as factory.
New member, Milton53 Has 18's on all 4 of Miss Violet, a 04 Ultra. Says he did extensive research on this. Looks good.
BlueStreak
What wheel & size did you use. Thanks
If you use the "> Quote" button in the post you are commenting on then others will have a better understanding of your statement or questions.
1 - 11 of 11 Posts
About this Discussion
9 Participants
xoxoxoBruce
Chevy SSR Forum
Full Forum Listing
