1 - 4 of 4 Posts
I had a new sound system installed ,speakers, sub wolfer, amp, and now the chimes for doors, gas low, turn signal left on, ket left in igniton, etc, does not work. I know I could take it back to the store that installed it but that would really be a hassle. Does anyone know where I might look for a sollution? Thanks, Edd
These chime functions are all controlled by the factory head unit, it is possible to add an
extension wiring harness and reinstall the factory radio somewhere inconspicuous,
than you would regain your chimes, your installer should have known this.
chimes.
sounds like they may have left something unpluged on the bose amp. I just had mine redone radio and all there are several things that run thru the amp besides the radio. We took it out to put one of the new amps there and figured that out. What you are talking about I believe runs thru the bose amp box.
Hope this helps. :banghead :cheers
It will be better in the morning. :D
1 - 4 of 4 Posts
