1 - 20 of 21 Posts
Just started this morning, a pretty loud clicking noise coming from what seems to be under the dash on passenger side ... Happens when truck is running. When it’s happening as the blower for the a/c slows with every click and lights seem to be dimming at same time clicking sound happens. Any ideas? Please! I recorded a video of it with sound and can send it to anyone in case anyone might have better insight on what’s going on
Likely the outside air blend door actuator has stripped a gear tooth. Lots of threads here discussing the issue. Here’s one to get you started: https://www.ssrfanatic.com/forum/f5/blend-door-actuator-replacement-60548/
Mine broke last year and I was sble to replace it following Dragon’s instructions.
While I would normally agree it would be a blend door issue, it should not cause any problems with lighting, power or any other equipment. Sounds like you might have a bad fan, causing a short and creating power fluctuations. I would NOT operate it until someone did more troubleshooting on it. Fan is easy to get to, right there under the passenger dash.
Unplug the fan and see if the problem goes away, if so I would search for a new or used fan to replace it with. If not, tell us what disconnecting the fan motor did if anything to change the issue.
:agree Sounds like the Blower motor.
2004 Slingshot Yellow
Leaves and debris fall into the blower intake through the cowl vent under the hood and fill up the squirrel cage causing it to make noise and get unbalanced. It tears up the bearings and then fails. Its easy to pull the blower from under the dash. See Dictators DIY Library for removal instructions, replacements are still available.
Easy is a relative term. Easy if your skinny and can stand on your head, not so easy if your old and fat. ? I’m in the latter category and did change one though, so I guess anyone can do it.
Reactions: RedlineRyder
So, was the Blower motor bad? or was it leaves/trash in it?
Last log in was the 26th..... hope we get an update, I hate it when you don't get feedback after offering advice........
Oppps----my mistake. Shadowman was not the original poster!! my senior moment.
Not sure, but it had a lot of debris in it. Since I had a new one in my hand I just decided to replace it rather than put the old one back and risk having to do a do over.
Reactions: nj6969
Hey, a new motor is under 50 bucks, and they are a pain to change out, especially if you do it twice. Just sayin..........
Daily Driver
It was the smart thing to do. Hook the old motor up to power, through a resister pack if possible, and if it's quiet keep it for a spare. :thumbs
2006 Redline FPR 6 Speed
Dragon's cowl vent covers will fix the debris problem and they really add to the underhood bling. Great work again Mike! Bill
Discussion Starter #18
Sorry for the delay fellas, blower motor is good and clean. I have a feeling it may be one of the actuators. Haven’t had a chance yet to take it apart and look at it. I do have a video I recorded if the sound of someone would me to text or email it to them. Thank you again for all the advice and inquiries! I can’t tell you how valuable everyone on this forum has been thus far!!
Discussion Starter #20
A side note that I just figured out since the noise has been happening ..... if I press the recirculate button, it blinks three times and then turns off. It doesn’t stay on. Idk if that helps anyone out. Thanks again
1 - 20 of 21 Posts
