:frown2:
MY six speed master cylinder has crud/crap inside the res............I removed the cap and used a Q tip and got most of the crap/crud out. The prior owner and records that I have show he had a new clutch setup (LS-7) installed in 2012. The prior clutch was shot and they derermined that the LS-7 flywheel/pressure plate was a good replacement. The Dealership invoice shows they did all that and added DOT 4 (synthetic) to the clutch.
Clutch works just fine, I'm just concerned about the crud/crap that I found inside the res. as I've never seen such a build-up of any such crap in a brake master cylinder res.
Anyone else with a six speed stick.............had this problem:frown2:
