I got the new radio and rear view camera installed. I also moved the old R.V. camera to the right front wheel as a curb cam. The monitor is installed in the ash tray and I can toggle from front to rear wheel. The system comes on when I open the ash tray and goes off when closed.
The new rear view camera has active lines that curve when turning so that you can see where you will end up if you continue backing.
It also has a front camera that I installed just under the grille to see that curb as I am parking. Just touch the screen and it pulls it up. You can also access the backup camera while you are driving in case your rear view mirror loses power.
Jack
Jack
