My wife and I noticed a cut on either side of the cushion at the base of the storage area for the top on the left and right side. It is now cut on both sides where the top comes to rest when in the down position. I don't remember seeing this before. Is this normal or what? Just curious if there is an adjustment needed or what? It seems strange that the cushioning material at the base of the box where the top is stored gets cut when the top comes down. You can view this if you lower the top and then just stop prior to the top going into the box where it is usually stored when lowering the top. I think it is hitting too hard on the cushion and causing the tear. What do you guys think? Do you need me to post a pic?
