Anyone who knows or has changed out their differential cover please advise. I am installing a Torsen differential cover in place of the stock cover. I know I must drop the Panhard link bar so...do I just put a jack under it or do I need to support the axel as well? Racesport
You just have to unbolt the Panhard bar and set it aside. The Panhard bar is just there to keep the axle centered between the frame rails. There should be no load on it when stationary. You can then replace the cover and re-install the Panhard bar when done.
