1 - 11 of 11 Posts
I noticed my hesitation problem goes away after with motor warms up over 200. In the morning, I crank and go. I didn't see anything in the manual about cold engine warm ups.
Does the 6L need a short warmup? :confused
Will running it cold like I do screw it up in the future? :confused
My opinion is that it is OK to start and go, so long as you are gentle until it gets into the operational temp range. WOT on a cold motor is asking for premature wear issues. When I see the needle reach the middle left mark (180, I assume), I am usually about to get onto the main street and I don't hesitate to use part throttle at that point. Prior to that, I've been running below 30 mph.
Rule of thumb for me: I avoid WOT below the point where the cooling system is regulating on the thermostat.
I'll let the "experts" weigh in on this for a precise answer.
Its wise to let the engine "warm" up a bit just to get the oil flowing......this is according to our engineers at work..(Toyota Motor Mfg) Many of them are from GM plants and are familiar with GM engines :seeya
Mike,
That is probably safe, but in my opinion, what you should be more worried about is oil temp. In my Vette, oil temp lags coolant temp by a lot. I don't get on the gas more than very easy acceleration until the oil is at least 150 degrees. On the Vette, I can call up oil temp on the DIC. :cheers:
Joe Schuhriemen said:
We all need a short warmup in the morning. Exercise is always good. It gets the blood flowing. And, we all know the best exercise around.
Well, I love my truck, but not that much! :)
1 - 11 of 11 Posts
