1 - 3 of 3 Posts
Hi all,
Where can I find the tool needed to help remove the door panel? The part number I guess is J38778. Who would have this?
Resident Rocket Scientist
Door Panel R&R
You can actually remove the panel by hand one the three screws are removed. Use your fingers to pull the front lower corner out. Once that one pops loose, the others are easy one at a time. If the finger trick isn't enough, you can use a putty knife wrapped in a shop rag or towel etc and slide it under the door panel near the front corner while pulling with the other hand ot for a gap. Then you can pry the panel up to pop it loose.
Worked for me and no scratches...
1 - 3 of 3 Posts
