@Stickman05$ I can tell you what all comes off. Starting on the inside you have to remove the sill plates because there are screws that mount the new rocker moldings to the body that need to be drilled. To get them off I removed the covers that go between the sill plates and the carpet and also the lower kick panels. Remove the push in pin that holds the kick panels to the panel between the carpet and the sill plates.
On the outside you will remove the front fender extensions, the rocker molding and the rear fender guards. Of course if you have running boards those will come off first. To get the rocker moldings off you have to remove the fasteners on the lower inner fender wells both front and back. There are brackets with studs holding the factory stuff in place and use nuts all 10mm if memory serves correct. Putting the new ones back on you can spend a lot of time making the original brackets fit with cutting and grinding on them or use bolts and washers in their place. I was going to make the stock brackets fit but after all the grinding I would have needed to do I would have had to have them replated or painted them so I just went with some factory bolts with washers on them already and nuts.
Depending on how the paint is on the fenders under the rear rock guards that area may need attention and leave it up to the body shop to make that call. My Blur had some not so great body work done prior to me owning it and they had painted the one side rock guard on the truck and cleared it to the truck. So taking it off pealed the clear around the rock guard. So that panel got resprayed to fix that.
@TXNSSR can go into more details of where he had to adjust the rockers to fit. Mine had already been fit to another truck before I got them so it was a lot easier for me.
