1. Ground head off small end of pin.
2. Had to drill pin.
3. Punched out pin.
4. Pin is shoulder type with flat spot on small portion of pin to stop pin from turning. ( I don't know why)
5. Unassembled Door Check Link.
Have not figured out repair yet. Because the small locking part of the pin does not turn, the upper hole on the bracket wears, elongating the hole. THUS "CLICK, CLICK".
I will post pictures if and when I get a fix for this.
Dick, do we have pictures of HOW to remove door panels ? Do you have any new door checks in stock ? Where do we get them ? Is there a fix for the old one, drill out and a new bolt ? Thx
I understand that Honda uses the same door check. I am trying to cross that today.
I have not spent time on the fix of the old one. Between, new rims, lowering my R, H.I.D Headlight System having my seats done, having spent any time looking for a fix.
Our infamous Door Stop “Click” is caused by the OEM bolt having a shoulder only the length of the rubber and not THOURGH the doorjamb bracket. The top part of the bolt wears and the bottom is pressed into the bracket where it cannot move, when the Door reaches different open settings the bolt “Clicks” against the bracket and the noise is transferred to the metal doorjamb.
Fix.
1. Buy a 3/8” X 5/8” shoulder bolt, 3/8” washer (I used Nylon washer) and nylon lock nut.
2.Remove the Door panel from SSR.
3.Remove Door Stop and grind small end off bracket bolt, punch out old bolt.
4.Drill Doorjamb Bracket holes with 3/8” drill, both holes.
5.Drill rubber arm hole with 3/8” Drill. Just one pass, don’t make hole large.
6. Put NEW Shoulder bolt thru bracket hole, rubber and bottom hole, put 3/8” washer on bolt, install lock nut and tighten.
7. Reinstall Door Stop on your SSR.
Done.
Cost? $1.78
No More “Click”.
You can purchase a NEW Stop from your Dealer. Only matter of time before the “Click” returns. Cost from Dealer $47.00 plus Tax.
The same Door Stop is used on the Cadillac 2007 CTS
Part# /D-67D-CTS or 6D10-031
You can go to the Thread "Door Check Link/Pictures on how to remove the Door Stop.
This is a fix.
Door Stop “Click” fix/Pictures
Fix.
1.Buy a 3/8” X 5/8” shoulder bolt, 3/8” washer (I used Nylon washer) and nylon lock nut.
Done.
Cost? $1.78
No More “Click”.
Part# D-67D-CTS or 6D10-031
1. 10mm bolt removes bracket
2. Remove rubber boot on door, two nuts to remove, take assembly out.
3. Grind small end of bolt off
4. Punch out old bolt
5. Door Stop disassembled.
