Drive your spouse nuts :confused
With some quick quiz facts on the 03 / 04 SSR.
(Taken from a G.M. "03" training manual)
LM4 = 5.3L =325 C.I.D.
BORE 3.779
STROKE 3.622
COMPRESSION 9.45:1
FIRE ORDER 18726543
PLUG GAP .06 IN
CROSSBOLT 6 ON ALL CAPS
DEEP SKIRT BLOCK
COATED PISTONS / TIGHTER CLEARENCES
PLATINUM PLUGS GOOD FOR 1000,000 MILES
DRIVE BELTS GOOD FOR 150,000 MILES
2 FANS 1 ON @ 108* 226f
2 ON @ 113* 235f
1 ON @ 185*F AC COOLENT
03/04 SSR QUALIFYS AS A ULTRA LOW EMISSIONS VEHICLE W/O EGR
TRANSMITION 4L60E
TORSEN DIFFERENTIAL 60-70% POWER TO BEST WHEEL TRACTION
STEERING 16:1 REAR STEER
FRONT UPPER BALL JOINT LUBE FOR LIFE
REAR 5 LINK WITH OUTBOARD SHOCKS
4 WHEEL 13’ DISC BRAKES
DUAL CALIPER FRONT
SINGLE BACK
TRW ANTI LOCK
ENGINE COOLENT DESIGNED TO LAST 150,000 MILES
TOP HAS 8 CYLINDERS WITH 16 HYDROLIC LINES
AC MUST BE OFF TO LOWER TOP AND WILL NOT DROP IF VOLTAGE IS BELOW 10V
LID EXTENTION PANNEL IS SMC PLASTIC
EXHAUST HANGERS TO ADJUST TIPS
DRIVERS SIDE FOR HIGHT
PASSENGERS SIDE FOR CENTERING
BORE 3.779
STROKE 3.622
COMPRESSION 9.45:1
FIRE ORDER 18726543
PLUG GAP .06 IN
DEEP SKIRT BLOCK
2 ON @ 113* 235f
TRANSMITION 4L60E
DUAL CALIPER FRONT
SINGLE BACK
TRW ANTI LOCK
