I removed the drivers side rear inner fender well liner and found the liner has been cutting through the wire loom on to of the chassis. This could become an electrical nightmare if I cuts through the wiring. See photos.
The area is located where the liner turns in the corner.
Discussion Starter #4
You may have to remove the tire unless you can peak around to where the liner is split. This liner was actually sitting on top of the loom and I’m not positive either the loom or liner can be repositioned. It cut through like a knife.
My First Permagrin !
Thanks oldxr for the heads up on another possible problem .
That's why this forum is the best , I learn something new everyday . Dave
