Has anyone ever tried putting an 05/06 set in an 03/04 and if so did anything work?
S Stlhotrod · Registered 04 Black, 05 Black, 05 Aqua Blur Joined Dec 31, 2017 · 3,754 Posts Discussion Starter • #1 • Jun 19, 2018 Has anyone ever tried putting an 05/06 set in an 03/04 and if so did anything work?
D dave rasmussen · Premium Member Joined Sep 10, 2013 · 4,257 Posts #2 • Jun 19, 2018 I don't think so. They are not the same. I don't think that can be done. I know that they are not plug and play. Dave
S Stlhotrod · Registered 04 Black, 05 Black, 05 Aqua Blur Joined Dec 31, 2017 · 3,754 Posts Discussion Starter • #3 • Jun 19, 2018 I know they have different gauges in them with the exception of the battery voltage, but the wiring harness is the same and has the same end on it. That was why I wondered if anyone had tried them in the other year application before.
Dicktator · SSR Pit Crew Joined Nov 2, 2006 · 13,167 Posts #4 • Jun 19, 2018 03/04 Gauge harness is NOT the same as 05/06. Different software in ECM. 05/06 has 200 times more software than 03/04. 05/06 has outside temp gauge on Auxiliary gauges and sensor in grill, 03/04 has neither. You can use digital gauges with pigtail. Dicktator SSR How to Library: https://onedrive.live.com/?id=3EF39D9F5ADCE5E5!853&cid=3EF39D9F5ADCE5E5
