Any of you that are planning to do the 3.73 to 4.56 gear ratio swap and also have plans to do a dyno run:
It would be great if you could do a BEFORE and AFTER dyno run, with NO other changes made meantime.
The reason is that I think finally found a good explanation of why the horsepower reported by an inertia type dyno (i.e. any Dynojet dyno) DECREASES if:
1. The run is made in any gear lower than the 1 to 1 ratio in the gearbox (which is 3rd on an automatic, and 4th gear on the Tremec 6-speed on the 05 SSR)
2. The rear end ratio is changed to a umerically higher ratio, and increases if it is changed to a numerically lower ratio.
The part I am missing is the MAGNITUDE of the difference. Hence, the above request.
IF I had been smart enough to have thought of this months ago, I could have had my own SSR dynoed before and after the gear swap at Walden (They have a dyno, and used it on my SSR AFTER the swap), but I blew that chance because I just didn't think of it then.
So, if anyone else is in the process, or planning to do the swap soon, please leep this request in mind if possible.
This effect does NOT manifest itself on steady state dynos (like the Mustang dyno, for example), only on inertia type dynos.
The data would be very useful.
Interesting tech article will follow as soon as I have all my ducks in a row. You will see and understand the significance.
p.s. The effect is substantial.
