JIM G and any other fanatics I have a plan to install an electronic brake controller for use on my trailers electric brakes.
(1) Does the 04 SSR have the pre-wired under the dash to receive the brake controller?
(2) I have installed a 16"Zirgo fan which runs on demand as the low and high speed wires from the fan are joined thus producing high speed fan operations whenever the low speed is signaled. I run hot or cold at a steady 195. Although I have not tested the system under trailer load up hill in hot conditions.
(3) should I install a transmission cooler as well?
(4) What supplemental cooling mods would you recommend. I am thinking of changing the OEM system coolant to a water wetter solution which yielded a 5 to 10 degree reduction on my street rod.
