Marc mentioned "There was only one minor complaint. I asked Glenn why doesn't the engine RPM drop off faster? He said that was one of his grips too. It seemed to take forever for the revs to come back down. I believe that it was set up that way to help insure a smoother transition between shifting gears. " in another post.
I have the same issue. It is also somewhat disconcerting when you take your foot off the gas and expect the compression to slow you down but you keep going for what seems like forever before you start so slow down.
Maybe we have an expert out there that knows how to retune this feature so it will drive more like a normal stick??? :banghead
