Have you ever noticed that on some SSRs the exhaust pipe on one side seems longer than the other? It is because the rear fascia is uneven from side to side with the exhaust. (Don’t replace exhaust)
FIX:
1.) Loosen both fore and aft and vertical bolts connecting the center fascia to the frame just behind the license plate.
2.) Apply light fore or aft pressure at the license plate in order to equalize the fascia gap. Maintain this pressure until the bolts are tightened.
PS this may have been brought up in an earlier thread, however someone recently asked me if there might be a fix to that problem.
Silver SSR has shorter right side pipe vs Black which is almost dead even
FIX:
