Factoid …. It is much harder to please your customer, when your customer is yourself. I have changed my mind so many times now. I just hope to have this hood finished for Woodward.
Some of you know I bought a second hood to customize so I can hang the factory stock hood high and dry out of the sun in case I ever want to go back stockish. I then made cardboard patterns for sheet metal to be cut. The hump is a 65 GTO and front end cut off. Mounting it backwards and adding two fans under it to exhaust heat for times like Woodward. The side nostrils are to take air in at speed. At this time I can’t make up my mind, about how far to flair the nostrils. It is 3/8” in the pictures; I had started at ¾” and know think it should be ½”. I want to keep it subtle, but not to subtle to not have attitude. It will be brazed in place and then lead. (no plastic) TIC TIC TIC Aug.20th bang!
