Well,
I have had the first service performed on my 05 # 21290.
Oil Change, went to Mobil 1 synthetic.
Had some shimying and slight shaking going on at front end at 45 MPH to 65MPH,
and then smooth over 70MPH. Turned out to be bad balance job from factory, and too much air pressure in all the tires.
Also had some black tape coming off of the wiring harness. I suppose that the tape they used at the factory must be the type you may buy in discount stores or something.
All in all, very happy with items and service performed. I will be returning to the Dealer to have the plastic rear fender cover re-set, as the double sided tape under it appears to be coming loose. I don't think they took into account the intense heat on the roadways here in Arizona.
:flag
:flag
