Wrong info about - Fix for cut in pad where top goes in 06 model
Update (9/26/05) 4:30 PM East coast time:
I took my car into the dealer and looked at the pad again.
I made a mistake. The 06 has the same pad. The flat spot I saw in the pad is the same as in our 03s,04s, and 05s. I mistook that as to where the cut was on my car and the others I saw at HomeComing. So, bottom line is that they still haven't done anything about the cuts in the pad for the 06s or older cars.
I'm still getting it replaced but its just going to do it again. I'll let Chevy worry about the replacements.
Sorry about that.
Carl
So the information below about a fix is wrong.
I don't know how else to explain it, but awhile ago there was a thread about a problem when the top is opened you get cuts being made in the pad at the corners in the bottom of compartment from the top being lowered into it. You normally wouldn't see the cuts unless you stop in the lowering cycle and look down into the compartment. You might have two diagonal cuts in the corners of the pad.
I replied during the thread that at HomeComing that had I brought this to some of the Tech's attention and that they said that they weren't aware about it.
This weekend I was able to look at an 06 model and I see where they have changed the pad and now have two spaces in the pad for where the top goes and it shouldn't cut into the pad any more. When I showed the cuts in my car at HomeComing we checked other SSRs that were there including an 05 and they had the same cuts, including the 05 too.
Since there were 06's at the HomeComing I should of had the Tech's look at an 06 to see if there was any fixes for the cuts but at the time I didn't think about it because they seemed totally unaware of the problem. Apparently Chevy knew of the problem and they fixed it in the 06's. So if you go to your dealer with the cut problem make sure you tell them you want the latest pad with the fixed pad from the 06 model.
Carl
Sorry about that.
Carl
Carl
