Has your key broken? Mine did, and would not stay on the key ring anymore. I had replacement keys made, but, they do not work very good. I tried fixing it with superglue and that didn’t work. Then I tried melting it back together with a soldering iron. That didn’t work either. Then, I got on the interwebby thingy and ordered some heat shrink tubing that you normally use on wiring. This type was coated with a special heat activated glue on the inside. I snipped off a piece the appropriate size, slid it over the break, hit it with a heat gun and TA-DA! So far it has stayed in place and works just fine. FYI. YMMV.
1st pic – Broken key
2nd pic – Fixed
:yellow:
Willie
2nd pic – Fixed
:yellow:
Willie
