21 - 40 of 60 Posts
Sign Up List:
1. Steve/Bobbie
2. Dicktator/Kathy
3. Beerbelly - Nick
4. Soren703 - Tom
5. topjimmy - Jim
6. cigarman - John/Jeanine
7. Sillypuddy - Ed - Change Multifunction switch.
8. crocksssr - Jeff
Rabbydoo&Marki - I'll call Dictator or Mike Morro to get the relay I need.
Discussion Starter · #30 · (Edited)
Sign Up List:
1. spc04 - Steve/Bobbie (Host)
2. Dicktator/Kathy - sit/watch
3. Beerbelly - Nick - helper and door handle repair
4. Soren703 - Tom - helper
5. topjimmy - Jim - helper
6. cigarman - John/Jeanine - helper
7. Sillypuddy - Ed - Change Multifunction switch. And helper
8. crocksssr - Jeff - watch topjimmy
9. chuckwagon - ?
10.Hotroddodd- Alan - helper
11.meterdoc-Jack - helper
12.dhenger -?
13,Gwillys41- Gary - helper
14.Showdad- Aaron - helper
15.Rabbydoo&Marki - Change/add something?
Doing really well but everyone is helping or watching.
Discussion Starter · #31 ·
Soundproofing, Roof seal upgrade, Blinking Brake Light, Bed Light, Door Handle repair, Pneumatic Struts, Roof Pump reservior, radiator support, trailblazer crossmember, ABS heat sheild, ignition switch?
Discussion Starter · #33 · (Edited)
Schedule lift time.
Radiator support - 4 bolts, Shift Kit - 1 bolt, Heat Shield - 2 bolts, Trailblazer crossmember - 4 bolts.
These are quick to do, usually.
EBCM, Lowering, Shocks, Springs etc. takes to much time, not allowing other to get work done.
No lift required: Bed Light, (do it before fire), Blinking Brake Light, ignition switch, Door Handle Repair, etc.
2005 Smokin Asphalt 6 speed
Update! I plan on finishing putting in LED lights up front, and do some soundproofing. If there's time to get on the lift, install new rear bump stops.
I just replaced my bump stops, they are super easy, it took me longer to jack the truck up and take the wheels off than it did to replace them.!!!🇺🇸
Discussion Starter · #37 · (Edited)
Sign Up List:
8. crocksssr - Jeff - watch topjimmy turn wrenches.
9. chuckwagon - ?
12.dhengerer - ? - LED Headlights (I guess) and bump stops if time.
16. JIM C - Jim - Needs Jeremy Tune.
2004 Yellow SSR #10286
I will be attending. I would like some help doing adjustments on the driver and passenger windows. They are not sealing correctly at the top and all my tools are still in Minnesota.
Thanks, Glenn
PS it is great to be back in FLA with all the Florida SSR Fanatics!
21 - 40 of 60 Posts
